Turn on lights with siren on floodcam
I installed the floodlight cam but can’t figure out how to flash the light with siren when motion is detected. The option to flash the light with siren enabled but this doesn’t work unless I manually turn on the siren.
Is there a way to trigger this with motion? I have some unwanted critters in the backyard that would be deterred by these actions.
Not in a position to test this at the moment or I would but can later today.
Try creating a Rule that turns the Siren on when motion detected on the flood light camera. See below.
I am not sure if the rule will honor the the “Flash Light With Siren” option but it would be worth a shot.
Thanks I’ll give this a shot. Not sure if this will turn on the camera siren instead of the floodlight siren.
