Does Floodlight Pro require that the Motion Warning be off for the Siren to operate? What is the Automation instructions required to turn on Motion Warning during the daytime hours and Siren during the night. It seems like a schedule can be used for turning the Motion Warning on and off. Then I would use the trigger to assign a siren action when motion is detected.
If the Motion Warning is on then the Siren will not operate under any triggers.
