Trying to get an older sensor to work
I have successfully. (I think) Connected and older sensor that I found in a drawer to a hub that I bought used a little while ago. So I went through the initialization phase and the linking phase and I believe I connected it to the hub. When I select it in the wise software I get sort of a pinkish screen with a circle going back and forth closing and opening.
I then created an automation for when it sensed motion to turn on one of my wise bulbs in a lamp, just as a test. But nothing happens. Is there anything I can do to confirm the connectivity is correct? I think the center is probably a V1. It’s got a glass, or maybe a clear darkish dome on the front of it.
