In the app I’ve created two buttons to trigger ON/OFF the sirens from all my v3 cams. But from an unknown reason is not working. The app is on iOS system.
Check the “rules history” for when you would of hit those buttons last, what does the history tell you happened? Success? Fail? You can press them now to test, but it’ll take a few minutes for them to show up in the history log.
Checking “Rules History” I see Failed on each trigger with “Timed out” on the cams.
