Trigger rule
I have a few contact sensors on doors and a trigger rule set to turn on a wyze bulb when doors are opened. Have worked as expected for past couple years with rare problems. Now, for the past couple weeks it takes opening the doors twice to get the bulb to turn on. Opening the door once works occasionally but more often I have to repeat the opening, open-close-open again to get it to work. Anyone else experience this? Any fix or suggestions? I’ve deleted and reset the rules with no changes. Thanks.
What app version are you using to remake the new rules? Beta perhaps?
Couple of years? Sounds like you have a dying battery. Many will not recover once the battery dies. I suggest you replace the battery before it dies. At least you know doing it soon will insure the battery is not the problem going forward and most likely needs replacing anyway.
