Ok since the Wyze battery cam pro came out and from what I understand its meant to replace the wyze cam outdoor and I bought it so that I could use it. But to my surprise I could no longer see the travel mode option and only now realise that this option has not been included and it was the main reason why I bought that camera for. So I want to have the travel mode feature be available again and also below are the list of features that it should have and improvements based on my experience with the wyze cam outdoor.
1 - Travel mode with all its existing features
2 - Be able to open the wyze app offline and control the camera in travel mode instead of having to turn on mobile data to activate the app and then disable mobile data and be able to activate the travel mode and connect to the camera to configure it.
3 - Since the battery would drain even when connected to a solar panel when there is not enough sun, there should be an option to auto power on when the camera has been charged to a certain amount or let the camera charge to atleast 50% and then automatically power on from its dead state.
4 - When the camera has turned on after the battery was depleted, it should be able to re-enter travel mode and continue with the operations that it was at and not require the user to go back to the camera and re-enable the travel mode manually which is frustrating especially that if the camera is in the middle of nowhere or very high up.
5 - There should be the option to see for how long the camera has been running like a simple graph with the dates so that we can track if the battery was dead and not powered on and recorded for how many days.
6 - The moment that the user has configured the camera for travel mode and that he has disconnected, the camera should stay in travel mode and do its job as its one of the issues where it will say out loud that travel mode has been disable but on the app it says that I can log out and close and the camera will continue to record which was not the case.
7 - The options to have a status led change color or blink for some time, or like an audible sound thats on repeat for some time just after configuration to show that the camera has indeed entered into travel mode and that its recording.
8 - Led indicator light to show that its being charged and in operation when connected to solar panel. The user can have the option to turn it on and off.
9 - Add the options to be able to connect and view many cameras at the same time when in travel mode instead of going manually to each one and connecting and disconnecting each time.
10 - be able to connect to the camera and able to hotswap the microsd card or atleast give a message to reformat the card on site so that it can record normally and be done within the app.
11 - The moment that the storage is full, have the option to select to overwrite the existing data.
Other people can comment to add other features or fix existing ones.
