Toggle between two primary accounts
I have two accounts, one for home and one for work. They are set up to two separate emails and I was curious if there is an easy way to toggle between the accounts on try app without logging out and in each time.
The app doesn’t provide a “switch account” feature. No point in beleaguering that statement.
You might find some relief at home by using another smartphone. Doesn’t need to have/pay for cell service. I have a cheap burner phone that I activated long enough to get WiFi turned on, then just use it a home. Its handy. And I encourage this for another reason.
You can use a gmail account and create a google/voice account. Download the app, installed, login to the gmail account. Then go to Voice and assign a phone number. Now, you have a backup phone number that works on WiFi, - doesn’t need cell service, and can help you in an emergency.
Welcome to the Wyze User Community Forum @jess.barton29!
The feature you are requesting has been suggested before.
If you would like to request that Wyze add this feature, follow the link to the official Wyze Wishlist, vote for it at the top, like :heart: some posts, and add your reply post to support the request.
