Wyze Sense clasps holder so tight I find it hard to replace the battery. Adhesive"strip" hard to replace. Any suggestions or tricks? Any suggestions on “easy holders” so I can easily open & replace battery w/o all these complications? Placed Wyze Sense on front door & back door
I too gave up on the adhesive foam.
What I do is use a small piece 3M Velcro pad on the sensor and then another pad on the door frame to attach the sensor.
Then when I have to change the senor or the senor battery, I just pull the sensor away from the other pad.
Chas
Hot glue works the best for me, it sticks the sensors in place easily, and peals right off when I need to get it down
Check out ideaxtruder on etsy. Drew makes several different mounts for the sensors.
