Time lapse V4 not working?
Thank you for all the explanations, I really appreciate it.
I checked the firmware update on my app and it shows as “up to date” despite being on 4.52.9.3415. I contacted support and they suggested 6 procedures that I will try later.
I joined the Beta program and installed the 3.8,0,b705 Android version along with the firmware above.
I just finished a 24h duration time lapse with pictures every 3 minutes and the problem changed: it just saved a small part of it (4s of what should have been 16s). But at least it did not disappear as it was doing before. After that I did another short duration timelapse for a few minutes with pictures every 3 seconds and it did work as expected, resulting in a complete 8s clip on the album (just to confirm it is a bug on long duration only).
You’re welcome, and I’m glad that’s helpful.
In the current production Wyze app I’m using (3.7.8.702, not on the beta channel), it’s telling me that my Cam v4s running firmware 4.52.9.3415 are all “Up to Date”, and that’s pretty typical. Wyze often does slow or phased roll-outs of firmware and sometimes apps so that they can watch for problems and halt if necessary. Using a β app version, you might see some firmware releases sooner, but I don’t think that necessarily applies to getting production firmware versions earlier than non-β users.
Your description of testing longer time lapses is an interesting observation, and I still think that could be useful feedback for whichever app version you’re using that seems to exhibit the problem (so I’d consider posting your results—or linking them—to Wyze app 3.8 Beta Test 9/17/2025 for the app you say you’re using except that a newer Release Candidate version has been posted since then, and Google Play Store will probably offer that to you soon if it hasn’t already). The only testing I’ve done specific to this issue since I began reading about it has been for shorter time lapses (~10 minutes with a 6-second capture interval), and those have all succeeded despite some apparent UI glitches.
I forgot about my Wyze V4 timelapse test. It dis record a long 10 plus hour timelapse. I’m old and forgetful. Lol. (Beta)
About 293mb. 1 minute of video. I don’t know if anything was missing or not.
I only do timelapses for like when my tree guy took down the old oak tree or auroras or similar events.
I do see the need for some consistency for those that use it for business recordings etc.
