Hi, I tried to set up Wyze yesterday but my issue is cold air comes out for both heat and cooling tests.
Info about my system:
- Electric heating pump and A/C unit
- Old thermostat (currently reinstalled it) honeywell thermostat th6210u2001
What I have tried:
- Restarted the thermostat in the app
- Factory reset the thermostat using the physical button and restarted the setup process (two times)
- Confirmed breakers were back on
- Confirmed I followed wiring proceedure according to Wyze app
- Tried toggling the “Swap to Heat and Cool” toggle from OFF to ON via the Advanced settings in the app, which did not change anything
This is the wiring set-up of the original Honeywell thermostat:
Wires Y,G, R, E, C, O/B
I connected these to what the app said to do:
(I would post a photo of this, except new users can only attach 1 photo to a post which is the silliest thing I have ever heard of.)
Y, G, Rc, C, O/B, *
The thermostat has power and is able to be set-up in the app, but tests for heat cause only cold air to come out. Further tests manually trying to raise the heat also produce only cold air, even waiting a couple of minutes.
Any suggestions? I just can’t understand it, even after researching what all the wires do!
The E wire seems to be a heat pump thing. If it gets too cold it can’t use the fan/pump, and must heat up the coils directly (I believe). And thus why there is no “W” wire I saw often when googling these type of systems.
