Thermostat - Replace “Coast to cool” with auto/manual fan control
Can we get a firmware update or an app update that allows manual or automatic fan control? I had this as a feature with Nest, and it allowed me to run the fan continuously - which kept cold air circulating continuously, and saved me from the compressor cycling 24/7. It would be great to be able to manually control the fan in a similar manner, rather than leaving it to the will of Wyze. Not only that, but it is useful to be able to leave the fan running to thaw my coils in the event the radiator gets blocked (as it often does during cottonwood season).
You can run the fan manually if you go to the app, swipe up on “controls” and change the fan mode to “On” instead of “Auto” When you want to turn the fan back off, just place it on auto mode again.
