Thermostat not working
My thermostat was not working so I went to forget device to reset. Now thermostat won’t link to my WiFi
Hello @amnocline and welcome to the community.
I am sorry you are having an issue. If I recall you can try to reset the thermostat by pushing down the button for 10 seconds and I believe it will ask if you want to reset it. You should then be able to add it to the app again
Hey Jason, I am facing an issue while installing up Wyze thermostat. I have only 3 wires (red, white and green) connected to my existing thermostat out of 6 wires. I connect those 3 wires to wyze thermostat but it dont work, any help
