Connecting to existing thermostat
Hi all. I’ve just moved into a home with an existing Wyze thermostat installed. I’m having some difficulty connecting it to my Wyze app to take over control. Anyone have advice on how to do this? Thanks!
Welcome to the community @aksilver
Have you tried resetting the T-Stat and setting it up again? Or Putting it in Paring mode to see if you can connect to it:
Can you provide some details as to where within the Wyze App Thermostat addition\setup choreography you are having problems?
Note that the phone must have the WiFi, Bluetooth (available), and GPS Location enabled to install a Wyze Thermostat.
Thank you! All I needed to do was reset the thermostat by pressing the wheel for 10 seconds.
Great find… Thanks for the update
