I had a Honeywell thermostat, I tried installing the wyze thermostat. I have tried all the variations but I can get the fan blower inside to turn on to push any air though the vents. I can hear the outside unit turning on but I get nothing inside. This unit did not have a delay. We have heat strips if the helps. I worked right before I switched the thermostat. I tried running the tests but they always fail. Last night the house was 84 in Florida.
Currently I have the following hooked up:
AUX - W1 (I have tried E as well)
G - G
O/B - O/B
C - C
Y - Y1
R - RC
Please help.
do u have a heat pump?
