@Brian do I go off what the app tells me to do with the wires or do I change what the app says to what you put? App says E = * but you mentioned it as E =w2
this picture is according to the app and doesnât give me a heat pump selection just electric, oil, gasAlso old thermostat didnât have the c wire connected it was just sitting in the wall so I pulled it out to connect to the wyze
Usually we install to W2, but the * may work as well. Youâre choosing âElectricâ during setup?
Yes Iâm choosing electric
Wyze is suppose to be emailing me to help. Thank you i may have to call a local hvac to come do it
Make sure you follow the wiring for the correct HVAC system you have. Bottom is heat pump and top is conventional gas.
Looks like I labeled for conventional gas and need to do it for Heat pump. I will try this thanks
I had the same issue âG cableâ not being detected, all the wires were on the right place, I kept reinstalling, factory resetting, and same issue. Until instead of looking at the cables I decided looking behind the thermostat unit. Turns out the pin that goes into the G hole was bent.
All I had to do was just unbent it and make sure it goes in the hole like the other pins. Now itâs being detected and everything working is fine. Hope this helps someone in the future.
