What is the deal with the thermostat I did the update and now every 24 to 48 hours it goes off-line I have to completely reset the furnace to get it to come back online the thermostat will still work on the wall but cannot be used from the app on the phone unless furnace is reset since the furnace is what powers the thermostat
When you power off your furnace and back on, essentially you are rebooting the T-Stat. You can also removed the T-Stat from the wall and wait for about 15 seconds and the plug it back in.
Before you do it the next time, take a look on your T-Stat and see if it lost WiFi connection. You will know this as the device will show the WiFi icon with a line through it.
Also, can you provide your App Version as well as the FW version of the T-Stat.
I am running version 1.2.3, which is the Beta FW described here:
The icons indicate that you are not connected to WiFi, which is why you cannot control the T-Stat via the App. The Snowflake looking icon indicates you have set the T-Stat for AC only and Not Heat or Auto.
Now, if you want the Beta FW for the T-Stat to see if it fixes your issue go here and register for Beta Testing:
Then load the App and when you enter it, go to Account, About, Beta Program, Click Edit in the Top Right, and then select T-Stat save all changes and back out to the Account Menu. You can then go to Firmware Update and the T-Stat FW should show up. you can also go to the T-Stat, Settings, Device Info and then go to Firmware and perform the update.
Note: Not sure you need to download the Beta App to do this, you may be able to do it once you sign up for the Beta Progra,.
