There is an audible noise (chirp or ding) randomly coming from the Wyze Window Cam without an error code
I have installed two new Window Cams. Both are randomly making a ding ding or chirp chirp sound coming from the device. This is not on the recording. I have MicroSD Cards in both. It is recording video. I have factory reset the devices. I have removed and reinserted the cards. I have also reformated the cards. The cards are PNY 256GB Elite-X Class 10 U3 V30 microSD Flash Memory Card. If I turn off SD Card, the noise doesn’t happen.
Welcome to the Forum, @liontdb97! :waving_hand:
I have not seen other reports of this, and when I began reading your post my first thought was that you may have had two-way audio enabled at the time and so you were hearing sound from the Cam that originated at your phone. Your mention of being able to stop the noise by disabling microSD card recording seems to indicate that it’s not a two-way audio thing, though. That’s weird.
What did Support say when you contacted them?
I need to eject the SD Cards and format them in a computer to make sure it is exFAT. More to come.
Are you hearing the chime sound that the camera makes when it’s powered on and you insert a microSD card? Some Cams make a double chime sound when inserting the card, and when I tried this with Window Cam a few minutes ago I heard a “ding-dong” sound. Is it anything like that?
I wonder if there’s a problem with your microSD cards and if trying different cards would make a difference. While I think the in-camera format is usually sufficient with a good quality card, some users swear by the SD Memory Card Formatter, and I’ve occasionally used that, as well, especially if I think I might have a card problem that I think this tool might “refresh” with a full --overwrite format.
If formatting your cards doesn’t resolve this problem, then I’d be inclined to try different cards and wouldn’t hesitate to submit a log (or logs) from the app and then follow that up with a Wyze Support ticket referencing the Log IDs. If your cards are felt to be good (format and work in other devices as expected, etc.), then I’d wonder if there’s an issue with the readers in the Cams.
This is my hypothesis
I agree. It sounds to me like the camera is repeatedly recognizing the SD card, and then losing recognition of the card, and then it comes back online again. This would explain the repeated beeping every time it recognizes the card freshly again. Swapping out the SD card, with a different card should help to tell you if the issue is with the SD card itself, or with the cameras SD card reader.
If it turns out that the SD card is fine, but the SD card reader in the camera seems to be the problem, something you could potentially try is to reset the camera back to factory settings and set it up again from scratch. Sometimes that will force everything back into a a functioning State. If that doesn’t work, your last prayer would be to flash the firmware back to a previous version and see if that fixes it. Otherwise, I would be inclined to think that the SD card reader in the camera is malfunctioning.
Thanks for all the comments. If anyone else randomly hears a chime or sing that the cam makes when you have inserted a SD Card, the format is wrong. You need to format the card on a PC to exFAT. After doing that, the problem went away.
I’m glad you got this working, and I appreciate your taking the time to post an update! :+1:
So far I’ve tried only a 32 GB in Window Cam, so I wonder if it has an issue with internally formatting larger cards. That might be something to look into. :man_shrugging:
Yeah, that’s what I was thinking.
I haven’t yet seen any flashable firmware made available for download with Window Cam. Since it seems to be based on Cam OG and Wyze hasn’t posted any Cam OG firmware download links (at least to my knowledge), I wonder if this will ever be an option for this model.
Wyze Window Cam may have an SD Card issue
Problem
Wyze Window Cam randomly disconnects, then reconnects, the SD Card, letting out a “doorbell-like” chime each time.
Root Cause/Theory
Reference: There is an audible noise (chirp or ding) randomly coming from the Wyze Window Cam without an error code - #8
In that thread, the theory was that the SD Card wasn’t formatted properly.
That usually would happen on first use, not after the fact. Usually.
In our case, the SD Card was full. The message on the page indicates that new videos would overwrite older ones; that doesn’t seem to be happening properly, which is a problem.
We did notice that the size was .1GB off from the max; so it’s possible that the camera wants to write first before deleting older. But that doesn’t make sense - it should detect how much storage it needs, delete those, then write new.
It’s important to note that of the five cameras in action and ten total over multiple years, this is the only one to have this issue; so we suspect it’s something specific to this camera that isn’t right.
Solution
In the Wyze Cam app under the SD Card settings, do the format. It actually didn’t take the first time we did it and we had to do it a second time to see the storage drop back to zero. For this camera, we’d only need the footage in the event of a situation, which there were none.
[Mod Note]: Post moved to more relevant existing topic discussing this same product and/or issue for better visibility within the community.
Welcome to the Forum, @CasualTalkRadio! :wave:
For a problem like this, it might be important to note some additional details about the situation, such as…
  • Wyze app version in use
  • Window Cam firmware version in use
  • microSD card brand/size/format (FAT32, exFAT) in use
The most recent Window Cam firmware I’m aware of was supposed to address some microSD card issues:
What you’ve written makes me wonder if there are ongoing issues with some microSD situations with this Cam that still need to be addressed in a future firmware update. If you believe that’s the case, then I’d suggest submitting an app log and then sharing your Log ID in that Wyze News firmware release announcement topic (linked above in the quote) with a description of the problem and your observations, along with the details I noted above.
