Sometimes I will get alerts that show on my phone and I look at events and there is nothing there,
five to ten minutes later they show up.
I can’t seem to find configurations settings that make it predictable like it was with the old app. Is there a install manual someplace that gives notes on how to install and set up the new app.
Everything was working perfect or as normal befor the app changed…
thanks.
pvp
I’m not using the new 3.0 app. This is all I can find.
I haven’t noticed that, events are there right after the notification. Many have found that “quirks” with the new app are resolved by uninstalling and reinstalling it. Seems maybe the upgrade process doesn’t completely remove all the old stuff potentially.
NOTE - do not uninstall the app if you are still on the 2.X version. That likely means your device is not compatible with 3.x and you can no longer do a new install of 2.X!!
