The lights don't stop - Wyze Cam Floodlight v2
Hello,
I have a Wyze Cam Floodlight v2, and the lights won’t turn off. They stay on continuously.
Here’s what I’ve tried:
  • I checked the “Floodlight settings” (see image).
  • I reset the application.
  • I reset the camera.
  • My network is functioning properly.
However, the lights remain on. I’ve adjusted the brightness to the minimum level (power 1) while waiting for a solution.
Thank you in advance!
I have the same issue. Although set to detect motion, the lights come on at Sunset and do not shut off until Sunrise.
