Hi, I did the latest update last week and now my camera won’t connect to my wifi and customer service said I need a new camera. I am out of the warranty period. Has anyone else had this happen? Thanks
I think you should try to add the firmware via these directions on the second paragraph. Follow the directions as written, use a clean 32GB or smaller SD card and re-name the file as directed.
Welcome to the Wyze User Community Forum @klean!
Wyze has recommended that you try a Factory Reset first and report back here if that works. They are working on eliminating this issue.
If that doesn’t work, then the manual flash procedure @Antonius linked is the next step.
Here is where you can download the Firmware:
https://support.wyze.com/hc/en-us/articles/360024852172-Release-Notes-Firmware
