Started updating new firmware (3 outdoor cams and base station) one camera updates the base station started but failed. now everything is offline and no option to continue updating
I would suggest you up date this way: Do the cams first.
I attempted to update my base station and it went offline and is solid yellow. Not had this issue before and power off/connect with different Ethernet cable to router etc doesn’t help.
@jlreese
They have paused the update, you may want to add what happened to you here
Thanks Jason,
I did communicate with Li Tan over on the Wyze Labs Beta Testers facebook page and contacted support this morning as recommended to initiate a replacement. The new firmware bricked my base station although this didn’t appear to happen to everyone. A reset with paper clip did not help. I understand that once you get a solid yellow light there is no going back. Part of being a beta tester though! ![]()
