When it come to “Finishing setup” it just hang there and fail connecting.
Reset the router to factory settings then boom work very well. Good luck all
I decided to try with an apple device and was able to add it in. It does not work on android devices. Wyze should either fix this or stipulate that adding new devices such as the switch does not work with android.
Are you on the latest Wyze app version or a beta version
Latest version
