Support Shoutouts – Real Stories from Our Users 💬
They show Wyze Chime, which is an accessory for the original Wyze Video Doorbell (Wired)[1], and that product page specifically notes that it’s not compatible with Video Doorbell Pro. They also have the “Universal” Wi-Fi Chime, which is supposed to be compatible as a chime for all Wyze Video Doorbells and Cams, but that one’s been sold out for a while. I don’t recall ever seeing Chime Pro—which ships pre-paired to Video Doorbell Pro and acts as its Wi-Fi hub/gateway, as noted in the Help Center articles I linked previously—available for sale as a separate accessory.
  1. This is the original “v1” doorbell. ↩︎
The Wyze Video Doorbell Pro comes with a chime that is pre-paired with the doorbell. You can not replace it with another Chime Pro, you have to replace it as a whole unit.
I’m glad you like talking to someone in email because according to polls people hate it. It’s slow, often no response, and you go around in circles more often than not. I really wish’s customer service was still a thing.
I miss those days. You know where you could call someone who actually cared about the company they worked for, wanted to help you, and ensure your problem was fixed, not just a ticket taker who puts in a ticket for someone else to look at and eventually maybe get back to you. I’ve put in a lot of tickets over the 5 or so years I’ve had Wyze. And I can tell you more often then not no one gets back to you.
Long time customer says goodbye to Wyze
I have been a Wyze customer since its inception. Was delighted to find a reasonably priced product(s) that worked better than expected. I’ve purchased nearly every Wyze product made from Cameras, Security, Vacuum Cleaners to Sprinkler controllers. I would estimate that about 30% of the products I’ve purchased have degraded/failed, generally after the warranty has expired and always less than three years old.
As I experienced long ago with FOSCAM products, I see the level of customer service & support gradually eroding away. Initially, phone customer service was staffed by agents who knew the products, inside & out. Now, it’s the same attempt-at-resolution routine, some of which are:
· Power-cycle the product
· Verify firmware versions for both product & app.
· Reset & reinstall product
· And so on.
Your new AI ‘screener’ now does a good job of that.
The last step often is a request to send to the “Technical Escalation” department where the engineers obstetrically review the data for a resolution.
If you get to that point, it means there’s no resolution, no one will ever get back to you, the product is toast. I’ve had this happen more than a half dozen times. Just throw it away & get another one. My last replacement strategy was to look for used or refurbished products.
Other quirky issues:
Being informed after purchase that Sprinkler Plus Weather Service was additional, even tho advertised as included. Unable/unwilling to inform source of third-party software for Sprinkler Plus to find out why the app/program says it’s going to rain when National Weather Service says it isn’t. I didn’t resubscribe…..
Notifications are sometimes received up to 15 minutes after the event occurred.
Doorbell V2 – My voice to person at door is delayed up to 45 seconds and is very slowed down. Gave up, replaced it.
My product purchase sources have been Wyze, Amazon, Home Depot & EBay.
I bought three OG cameras at Home Depot, one was bad out of the box…….
Look at my purchase history, just on my Wyze account, nearly $1000 of products purchased……I’ve been a very loyal customer
This latest snafu is particularly troublesome. I had installed 8 water sensors. When tested with water, they all worked as they should. As with other Wyze products, I assumed the devices or app would notify me if their batteries were getting low or the device went offline or otherwise was not communicating. Imagine my surprise when I was looking at the app & discovered that 3 (38%) of them were offline. That means I could have had a huge water leak with no notification.
THEN, to find that I was unable to reconnect them to the system was shocking. I called in and after troubleshooting, was told the 3 sensors must be defective. They are all just two years old.
So, after confirming they are all out of warranty & complaining, I’m offered a $10 gift card!! Indicating that didn’t seem to be enough, it got bumped to $20.
To have 3 out of 8 sensors fail within a short time just two years old indicates either poor product design/engineering, construction or even a software issue that seems to happen with now a few of your products I’ve purchased.
I’m sorry, but you’ve now lost a long time, loyal customer. I will begin a transition to a competitor’s line of products. I understand I can store all of my camera’s videos locally on their top-of-the-line hub for the annual price of your CamPlus subscription.
Perhaps, their products will last more than two years……….Goodbye…..
please share this email with your “upper management” of the Wyze Wizard Team so they’re aware…..
Exactly how i feel about Wyze now!
They love you till the warranty ends.
After that, they offer you new “ upgraded “ product to be purchased !
Disgraceful !
Wyze don’t appreciate their customers and plans to continue to make our expensive plans the basic for the same expensive costs just so they can keep adding another expensive plan with what use to be the cam plus options but now cam plus is now basic and charging like 130 a yr for it which u can get free with other companies or by using an SD card. Now they have a more expensive option and u change to that for 200 a yr give it time in a few more months that will be made the basic and they add another forn300 per yr and then ur stuck paying 200 a yr for basic sine they don’t grandfather in long term customers so it’s time to put a stop to it by people getting together and all cancel same day and tell them why only then will the greed slow down or will they appreciate their long term customers.
IF EVERYONE WOULD CANCEL THEIR ACCOUNTS AND EMAIL WHY THEY DID IT I BET THEY WOULD GIVE US BACK WHAT WE ORIGINALLY PAOD FOR AND WOULD STOP TAKING US FOR GRANTED. BUT ITS IMPOSSIBLE TO GET EVERYONE TO JOIN IN CUZ PEOPLE WITH MONEY COULD CARE LESS CUZ THEY CAN AFFORD IT BUT THOSE WHO ARE SINCE DISABLED PARENTS LIKE MYSELF I CANT. 130 A YR FOR CAM PLUS CAUSED MW TO TAKE FROM OTHER BILLS BUT WHERE I LIVED WE NEEDED THAT SECURITY AND NOW THEY HAVE TAKEN THAT AWAY BECAUSE WYZE WANTS MORE MONEY FOR THE SALE STUFF WE ALREADY PAID FOR THAT THEY TOOK!
FOR EVERYONE WILLING TO STEP UP LET ME KNOW AND EVERYONE CAN CANCEL SAME DAY
IF NOT THIS WILL ONLY CONTINUE TO GET WORSE.
Shoutout to Support for being mostly unnecessary.
They’re still the go-to for Account and Subscription stuff.
Otherwise, this forum and general internet searches (which return Wyze official support and forum pages, as well as blog posts and videos from others) continue to work well for me.
Pithy questions and follow-ups get the best results. :slight_smile:
Just as with national politics & religion, I doubt you’ll get much of a following.
You can take your dollars elsewhere. For example, TAPO offers a local hub that will hold a huge amount of events on a SD or even HD. It costs the same as the annual subscription you mentioned. Unlike other competitors with limited capability, their products compare well……….
Real Story: I bought doorbell and two Battery Cam Pro cameras. One is a piece of [Mod Edit]! Keeps going offline. Rep does her queue card. This. Is stupid…manually burping the camera every day or two. Power diwn, firmware update, then bingo it works….for another day then [Mod Edit] of flaky low quality foreign made JUNK! I’m sick of it. Doorbell works flawlessly but other camera is [Mod Edit]! Looking for another company—maybe Safe Eyes!
TAPO looks like a good alternative……..
When I was unable to perform a firmware update to my pan cam v2, I contacted Wyze Customer Service. I was made aware via an email push a few weeks ago that there in fact is a firmware update, but my Wyze app states that I am on the latest firmware and therefore I cannot perform the update. The Customer Support rep, after exhausting his “script” of canned answers and could not resolve the issue, stated to me, “This issue could’ve been a software or hardware issue which could’ve deteriorated over time, and the best course of action would be a replacement.” BS!!!
He merely offered me a Wyze gift card to appease me, as the cam is well out of warranty. He also refused to escalate this to Tech Support!!
Today I Googled the same question, and lo and behold if I download the firmware update file from Wyze and flash it per their instructions, I can update the firmware in this fashion! SO WHY THE HELL DIDN’T THE REP TELL ME THIS INSTEAD OF GIVE ME AN ASS-ACHE?? My educated guess and gut feeling tells me that he had absolutely NO idea that this could be done, leading me to believe he either is very poorly trained and educated, has been instructed only to follow his “script” (canned) or does not want to pursue anything beyond the script.
Wyze Customer Service is at an all time LOW!
I have observed similar scenarios with 99% of the Wyze reps I have dealt with over the years. This is VERY disappointing, as I am very vested in my hardware purchases and use of Wyze products (ever since they first opened shop!)!!
So caveat emptor, e.g. your problems will not be resolved and you must purchase new equipment if you have any type of problem down the road.
Fellow Wyze product owners and users, what have YOU experienced with Customer Service? Are you satisfied? Have you ever been dissed like this? What pressure can be put upon the Wyze powers that be to force them into accountability?
Since I am vested, I need to put up with their BS. However, would I ever recommend them or give them a positive review? ARE YOU KIDDING??
[Mod Note]: Your topic and replies were merged to this more relevant topic for consistency in grouping Wyze Support feedback and for better visibility to Wyze.
The only time I ever contacted Wyze support was for a warranty replacement, and it was pretty painless.
I research/ask here for anything else, since dealing with 1st level (outsourced) support at any company is a frustrating waste of time.
Of course warranty support usually is handled without incidence. You raise a great point in asking for help here rather than with Wyze customer service, as this knowledge base here really does far surpass that of the hired help. Thanks for the insight and suggestion!!
I had a similar lousy experience with CS. I have 8 water sensors. All of a sudden 3 went off line & would not re-pair/re-install. Last battery level indication was good. Went round & round with tech support, out of warranty so gift card offer accepted. Look for my extensive write up/goodbye to Wyze elsewhere. Turns out replaced batteries, all is good.
I’m going to transition all cameras/video functions to TAPO. They have a local storage hub with huge storage capability for the same price as an annual subscription to CamPlus.
I’ll keep all non video Wyze products for now……..
I switched to tapo. Best decision i made. You won’t regret it. Once you get used to it the cameras are night and day. Haven’t had a issue and works likes it’s intended. Been using tapo since early December
Well, here’s the feedback. What’s all new about this new browser viewer web viewer it’s the same one that you guys had before you went back to the old way you can only view six cameras hit the arrow to view their neck. Set of six. A lot of us were betting about it. We didn’t like it. I want to view nine cameras on one page. I don’t want to see and they gotta move to the next six no one camera for one viewer for the whole nine why can’t you make this for nine why it has to be sick where’s the nine you know what I want my money back for all the cameras that I purchased and I want all my money back for all the service that I paid for.
Yes, I’ve have reached out twice for support and no one has ever responded to answer my questions.
In my last position if I ever done such a thing, I would’ve been dismissed :thinking:
Welcome to the Forum, @perdue.roberts! :wave:
How did you attempt to contact Wyze Support? I wonder if you may have submitted an app log and expected a Support response, as this seems to be a common user frustration. One recent example is discussed in Wyze Cam Duo offline. It’s important to understand when and how Support will respond.
If you have a Wyze Support Ticket number (this is not the same thing as a Log ID) that you can share here, then a volunteer can ping someone at Wyze to look into it.
I have had a very poor experience with your support team. I keep being told my order is being resubmitted, but I have yet to see any proof by email or in my Wyze account. The first time I reached out was two weeks ago, Wyze Ticket 5044188. I was told to wait. Last week, I was told that they helped me by resubmitting the order, but I have not received an email confirmation of that chat at all. Nothing from the order department. Not even a ticket number for the chat. When I reached out today, ticket 5061369, same story. ‘We are helping, but will not give you proof.’ How do I know that my order is being processed? I am about to cancel the charge because I never received the item. I would rather receive what I paid for.
I’m in Canada and foolishly ordered the wrong product being too excited and too much in a rush. I meant to order the Lock Bolt V2 but somehow purchased the Duo Cam Doorbell. How I made that mistake i still don’t know. Just too excited and rushed through it not looking really. I contacted the customer service via chat and was super happy the agent was able to cancel the order and send back a refund. I’ve since ordered the product I actually wanted. I will say the Lock Bolt V2 has been great. I really love the facial recognition automation to unlock my door handsfree. I know I can also set it to use my phones location but I don’t want it to make a mistake and unlock while I’m home.
I had read a policy that Wyze didn’t cancel or alter orders but they actually did for me. I can’t thank the agent enough. I would have been hassled with getting a return label, going to the post office to have it shipped back, wait for them to get it and confirm it and then issue my refund. It could have taken a couple weeks all said and done and that agent got it handled in minutes. Jayward was the agents name and I really feel they deserve a gift card for lunch or at least a company coffee cup or something. Thank you Jayward.
Visitor 81194885: Customer Journey
User: cancel order CA-156667
