Suppor Log
I really didn’t see a better place to put it so I am asking here since it is for a camera. I set up an OG outside with a outside power cable I purchased. It setup and was running for a couple of days but now it won’t connect at all. I tried to reset it and now it won’t connect so I submitted a log and got a log id but the email I got back said I won’t get a reply. So what’s the point? When can I do? Trash it?
That’s correct. This might provide some clarity:
You can contact Wyze Support to open a ticket if you want an official response from Wyze. If you want assistance from other users here in the Forum, then you can also share more details about your experience, specifically…
  • What can you add about this “outside power cable”?
  • Is it a Wyze Outdoor Power Adapter or something else?
  • Aside from attempting to reset the camera, what specific troubleshooting have you attempted?
  • Does the Cam seem to power up as expected (click of IR filter, status LED)?
  • Have you brought the camera indoors to examine it and try to connect it to your network closer to your Wi-Fi source?
Those are the places I’d start, but I think a big part of the frustration in this case is the confusion between app logs and support tickets, and that’s a frequent source of dismay among users.
Test the cam with a different power cable to determine which part failed (any micro USB cable and 5V USB supply/phone charger that puts out at least 750mA will work). If the cam works, then the power supply died, if not then it is most likely the cam.
Contact support, give them the log ID, and they should replace either part under warranty as long as it is under 1 year old.
It is the Wyze Outdoor Power Adapter. I have tried multiple wifi sources. Different routers with different SSIDs. Camera powers up and I get the Ready to connect message. I have brought the camera inside and tried several times to connect to the different routers on different channels.
dj
I will open a support ticket I guess. I would just make it automatic to open a support ticket when a log gets submitted but that’s just me I guess.
Have you tried factory resetting the cam, and in this indoor testing are you using a different power adapter to rule that out?
If you can’t get beyond “ready to connect” then that implies an issue with bluetooth. Or do you get as far as being able to select your network and put in your wifi password? In that case, you can temporarily try disabling 5ghz on your router so that both your phone and the cam are on the same band, see if that works.
Yepp. did that already. I did get it to connect a few minutes ago on the second router in the house. I had to set it to only 82.11 b/g/n mixed and not include ax. I went ahead opened a support ticket to get a better idea on what happened.
The only thing about AX that should be able to interfere with the OG (which is N only) would be if it had WPA3 enabled (including WPA2/3 mixed mode). Setting the router to WPA2 only can help with that.
You’re far from the only user frustrated and confused by this two-track system for logs and tickets, but that’s the way their systems work for now. :man_shrugging:
I don’t know if Wyze Support will still tell you (in their scripted response) that they’re working on a system that will allow support agents to have access to logs or not, but this is something they have said literally for years, and I have seen no evidence to suggest that there’s any truth to that statement, so take that for whatever it’s worth. Having said that, I don’t think front-line support agents are equipped to interpret logs, anyway, and that’s not a skill I would expect at that level. I believe those are best left to the engineers.
Thank you for supplying additional information about what you’re using and what you’ve attempted so far. I’ve personally found with Cam OG (the original version; I don’t have the 2025 version) that even a small change in distance (here I’m talking a couple of feet) between the Cam and Wi-Fi source can make a difference in whether the Cam can complete setup.
I also agree with restricting security to use only WPA2 (not mixed-mode WPA3+WPA2) on whichever SSID you’re trying to connect the Cam to, as that’s been problematic for a number of devices (not just Cam OG). I’ve had more consistent performance with these devices on my own network since migrating them to a separate IoT SSID that uses WPA2 only.
Right now it is set to both WPA 2 and 3 but is connected and working. It’s the only device on that wireless network now. If it happens again, I will set it to WPA2 only.
I did get a reply from support asking if I had Bluetooth enabled.
