There is no anomaly in the Playback function. It happens on Event videos only. So, it appears to be something with the Wyze (Beta) app and the Event Video playback.
Can someone with Android Wyze Beta app please double check me?
It’s not the set up, but something in the app. If I download the event clip, it’s normal. Only playback in the app seems affected. And it’s all clips, not just the porch.
I took a screen capture video that shows one example. The clip starts out looking normal, then zooms somehow.
I’ve cleared cache, no effect. Going to uninstall beta app and reinstall next.
thats very good to know, especially if its something that seems to be affecting others. thanks for the solution. @Mavens solution in post #7 if anyone sees this issue happening more often.
I believe it is associated with different screen resolutions - maybe only on Samsung phones(?)…
I can reproduce the effect in either “direction” by changing the resolution.
For example, I was originally on WQHD+ (2960 x 1440), and changed to HD+ (1480 x 720). So, from a higher resolution to a lower one, and the event videos were zoomed in (see previous upload).
I just changed from that lower resolution back up to the higher one, and the image gets smaller. If you think a log file will help I can certainly take one, since i can make it happen by changing resolution.
I put in a support ticket, with a log file… and a second log file requested by a second “Wyze Wizard.” When the third “Wizard” asked for the ticket number - again (which, by the way, is in the subject of email received from Wyze) - I gave up. Since I fixed this with a data clear, I’m no longer concerned about resolution.
I have been having the same issue for months. I know it has to due with Samsung screen resolution settings, but I attributed it to the beta app. It happens no matter what, and reinstalling does not fix it.
As I said one post above, clear Data, not Cache. Relog into the app, and it should fix it. If you change resolution again, it will have the same issue.
