Hi,
Is there a way to stop a leak alert from the hub or the keypad ?
I can do it from the app, but what if I’m away and my wife needs to stop an alert ?
Welcome to the Wyze User Community Forum @alcyon!
Yes. The Leak Detected HMS Hazard Remediation Alarm produced by Included Monitored Sensors in the Environment page of the HMS Settings, which is a different tone from the HMS Security Alarm, can also be disarmed from the keypad using the same Disarm PIN and button press sequence as you would use to disarm the HMS Security system or an active alarm.
Awesome, thanks!
