I had to remove a window sensor because the gap was to big. And it was only saying open. That sticky stuff was rock hard stuff. Can Wyze Cam send me anew sticky backing? Or what do you suggest I use in its place to reapply to new window location
Hello @hotfootedhiker, others recommend using 3M adhesive tape for the best results.
3m command strips are good if you think you might have to move something a couple times as they come off easy and don’t leave any marks
