I seem to have placed the small sensor too far away from the big one on my door. Is there a way to reposition the small sensor so it’s closer?
Hair dryer or heat gun on the adhesive foam tape? Heat it slow then it should come off without leaving any residue. Then try sticking it back on closer. It won’t be as sticky as when you first out it on but it might hold. If not a trip to Target or something and get a roll of 3m style foam tape for cheap and out that in the magnet part.
Thank you for the answer.
