I have a motion event that recorded the first 12 seconds to the cloud and then continued recording from the 13th second (to the end of the event) to my SD card? This is unacceptable. How do I get the full event recorded to my SD card? I got some additional information from this Q&A that states exactly what happened to me:
Hello! The Wyze Cam V3 will capture one 12-second alert video every five minutes when motion or sound is detected. Using a microSD card with the ‘record on event’ or ‘continuous recording’ feature turned on will allow the camera to record the rest of the footage that the cloud video does not capture.
If this is the way it is supposed to work, I have no use for this camera. I need something that records a full motion event to the SD card and reference markers to locate “events only.”
Thank you.
