Cloud and sd card
If I save clips to sd card will it automatically save to cloud also or just the card
Only the 12 second events are stored on the cloud. If you have the cam set to continuous recording all the videos will be on the SD card too.
Yes, they are separate operations. 12-second motion clips go to the cloud. The SD card can be set for 1-minute motion clips, or continuous multi-day recording.
https://support.wyzecam.com/hc/en-us/articles/360029811772-Event-Videos
But if I have local storage set to record events…not contiguous…will it be on the card and the cloud…or just card
Yes, all the events will be on the card if you have events only recording. It doesn’t need to be set on continuous if you just want the events only. The 12 sec events are stored on the cloud separately.
So to see what’s on the card it need to remove it and watch on the computer…correct?
You can view the recorded videos without removing the card. You can view them in the play back mode.
All these questions are answered in the first link above.
Got it…thankd
