Solar cam pan flipped view
The picture on the video is upside down. Was right and I touched a few buttons and somehow it flip. I brought the camera in but couldn’t find anything. Any suggestions would be appreciated. Thanks
Welcome to the Forum, @waterfun2222! :wave:
Did you perhaps enable Solar Cam Pan’s  Settings ➜ Advanced Settings ➜ Rotate Image 180° ? That’s the first thing I’d look at based on what you’re describing.
Yes I did! Thank you. :blush:
[Mod Edit]: Corrected “Solution” assignment to proper post to help other users with similar issue.
You’re welcome! Thank you for taking the time to post an update! :+1:
I’m trying to perform the Rotate Image 180 and it’s not doing anything. The timestamp and logo settings under advanced are also not changing the live view. I’ve reset the device twice, closed the app, logged out of my account and tried a different iOS device. I’m on the latest current firmware on the device and the iOS app.
Anyone else have these settings simply not do what they’re saying they do?
I haven’t seen that, but I don’t use iOS.
Rather than saying “latest”, it can sometimes be helpful to state your actual app and firmware versions, because that can be used to identify patterns if what you’re describing is affecting other users. You can also use those versions to check the appropriate release topics for the app and firmware in the Wyze News category (and/or the Beta category if you’re in that release channel) and stick a note in there to help get that to Wyze’s attention.
What additional detail can you provide about how you’re trying to mount/use the camera and what it’s showing, specifically the  Settings ➜ Advanced Settings screen? Sharing a screenshot or two might be helpful.
Welcome to the Forum, @msells! :wave:
I just got a cam pan solar and its sounds like its doing the same thing. Firmware and App are up-to-date.
It connects to wifi and I can see LIVE view, pan the camera around, but can’t save any settings, All the settings don’t seem to save when changing anything. I noticed this at first, just trying to rotate the image 180 degrees.
I wonder if anyone else is seeing the same thing? I just opened a ticket with support.
I have tried factory reset, adding the camera again with another phone…tried both Android and iPhone.
There is not much posted about these new cameras. Its hard to find help.
