Detection zone automatically turning off
I have a wyze solar pan cam. The detection zone automatically gets turned off even after selecting the desired zone area. Also, both detection range and motion sensitivity gets reverted to default mid range after setting them to far and high respectively. The firmware is the latest. Could someone help me with resolving the issue? Thank you in advance for your time!!
Welcome to the Forum, @velore.prasad! :wave:
What you’re describing reminds me of two other recent topics. In this first one, start at this post and read on:
This is the other related topic that comes to mind:
In this second topic, the solution seemed to be contacting Wyze Support for direct assistance. Reportedly they were able to push a firmware update that resolved that user’s issue with Solar Cam Pan’s settings not saving.
If you haven’t already done so, I’d submit a log from the app and then open a ticket with Support that references the Log ID you generate. If they seem confused about a possible resolution, then I’d also direct them to the second topic I linked above, because that seems to be the solution for now.
In the future, please note that stating the actual firmware version is probably more helpful to the community than saying “latest”. Because of the way Wyze has been phasing firmware distribution, what’s “latest” for you might not be the same version as for other users.
Thank you very much for your advice, Crease! The version I have is 20.0.0.1939 so I will contact Wyze to get a forced update/change in firmware. Thanks again!
You’re welcome! I hope that works out for you. If you’re able to get an update and that resolves your issue, then I hope you’ll take the time to post another reply here, as that could be helpful to the community.
Just letting you all know I was able to get the Tech support push a firmware update to 2.0.0.2041 and now I am able to change and save settings in the cam. Thank you team for your help. Appreciate you all!
I’m glad to know that worked out. Thank you for taking the time to post an update! :+1:
