Rotate Image 180 Toggle is Reverse
I have about four pan cameras. One started acting very strangely. The image appears opposite of what the 180 toggle indicates. I guess that’s not the end of the world but it also flips to directional control… left goes right and vice versa. Even stranger is that the vertical control is not affected. ???
I’ve reset it a few times, and it made no difference.
Is the camera mounted upside down or rightside up?
Right side up
I’d say delete it from your app, clear app cache, factory reset the cam by holding the button for 10-15 seconds, and re-add it. If you have detection zone or other settings you want to save, take screen shots before deleting so you can easily recreate them.
I might even take it a step further, instead of just deleting the app cache after deleting the camera, uninstall and reinstall the app. Then factory reset and re-add.
NOTE - do not uninstall the app if you are still on the 2.X version. That likely means your device is not compatible with 3.x and you can no longer do a new install of 2.X!!
