All of a sudden the camera view on my app is upside down & I dont know how to correct
I just got a Wyze Cam Pan & it was working fine & then all of a sudden the view on my phone app is upside down & dont know how to correct.
Check settings and then advanced settings. Is the rotate 180degree button flipped?
That was the problem. Thanks.
glad it was an easy fix for you.
That corrected it
