Is it unwyze to install the Cam Pan v2 upside down? If I do this is there a way to rotate the picture in the app on iPhone?
Several of my cameras are mounted upside down. On the camera settings, select Advanced, and then Rotate Image 180. Turn that on.
As @K6CCC indicated, the Pan Cam can be hung upside downa and you set the 180 degree flip to on. Some have reported a much better representation of the environment, not sure as mine is right side up.
Thanks. Easy when you know how!
