I just installed my new WyzeCamPan and the image is reversed.Upside down.What do I do to correct this?
In the advanced settings there is a rotate image 180 degrees toggle. From live stream, click the gear then advanced settigs. Welcome to the forums!
That worked. Thank you.
So if I installed a Pan cam and hung it upside down to protect it from the elements then I should be able to rotate the screen in the settings feature?
Yes…I have my PanCam hanging upside down in my garage and the setting reverses the image to make it viewable.
Thanks. I think that’s a great idea from Wyze.
Thank you
