Wyze Solar Cam Pan Firmware Version 2.0.12388 Set up Question, 11-01-26
Wyze Solar Cam Pan Model Version 1.2
Have set up my second camera, same as the first but picture is showing upside down. Have tried & retried the calabration any other suggestions. Thank you
is “Rotate Image 180°” turned on at: Setting: Advanced Settings for each of the cameras?
SJ
lindabussler, calibration only recenters the pan and tilt, it does not flip the image. Open that second camera in the app, go to Settings, Advanced Settings, and turn on Rotate Image 180. If it is already on, turn it off once, leave the page, then turn it back on, since a sticky setting can leave one cam inverted after setup. Also check that the second mount is oriented the same way as the first, because some outdoor mounts hang the body flipped relative to the bracket.
