I know there’s a few out now but some (Winix) brands lack proper support. They’ve got the air purifier part down, but have a hard time with the software/app. Could include an air quality or voc sensor and power on automatically, and or include scheduling from the app. I tried making mine smart with the use of a wyze plug but that can only power it off which is pointless because it already comes with an off timer. Would be great to have it on a schedule or triggered by a sensor.
Small but great, Wyze Smart Air Purifier includes the following features
Air Quality Sensor - can be viewed through app
Air Quality Indicator Light - located on top of the tower BLUE (Great) GREEN (OK) YELLOW (Fair) LIGHT ORANGE (Hazardous)
-Quiet But Strong
-Noise Level 50dB Or more or Less
I would like one as well. It would be great to have something similar to the Winix AM90 with standard filters that can last 6-12 months and that don’t cost half the price of the unit. I would buy several units.
There’s nothing inexpensive in the current marketplace that meets my demands. The cheap ones are loud and not smart. The expensive ones are…well very expensive.
Requirements:
standard-sized replacement HEPA filters
quiet / maybe similar to Dyson’s air multiplier
smart - including scheduling, sound/light monitoring to match run speed, air monitoring including history, filter life monitoring, etc
Hi, when are you going to offer wyze whole house air purifiers that includes ionizers, permanent hepa filters and heat and cold functions that work on the app? It would be nice to include air quality sensors that adapt the air speed to particles in the air.
I would love a wize air purifier with geo sensing or programmability through wyze app. Maybe even tie into the thermostat. A humidifier or dehumidifier that works in conjunction with the thermostat would rock too.
[Mod Note]:Your request was merged to this topic for consistency in grouping similar requests. You may also wish to comment on and/or vote for Smart Humidifier. Remember to scroll up to the top and click the VOTE button.
There are combined HEPA + electrostatic “filterless” air purifiers that work great – and won’t cost you $35 for a new filter that has to be replaced every few weeks.
