Siren triggered recordings to be tagged with SIREN
Siren “actioned” recordings in the Events list to be tagged with SIREN exactly the same way as PEOPLE, Pets, Vehicle, etc. are tagged. This would make Siren recordings easily searchable and identifiable. There is already a wishlist item to make Sirens a notification.
Update to this Wish List post: After discussing this with others, there seems to be a greater need than just Sirens to be tagged. Basically anything that is an action item should be tagged. Rather than combine them with the trigger tags, perhaps an entire new display of “Action tags” could be created and obviously be searchable so the end user doesn’t have to scroll through hundreds of recordings to locate there recording that was actioned.
It was also discussed, I don’t know that I totally agree, but use the Rules title (or the first 10 characters or something) since there can be multiple actions per Rule.
Don’t forget to vote for your Wish Item. It does not automatically add your vote
This is a good suggestion.
I actually modified this Wish List to the following:
