I have items that i have used for a while, and they eventually failed. (Colored light bulbs not connecting, or colors are off. Indoor plug makes LED Christmas lights barely work.)
My question, is there value with sending back old/failed products to be tested or investigated, to make future products better? Or should i just toss them?
If through your interaction with Support, they determine that a product return is necessary, then you can send it back.
Up to you, i am sure there are of folks that love to tinker on here that would love to get hardware they can dissect, try and fix, part out etc.
Sounds like something Big Clive would enjoy
I think it’s a good question. The last two warranty replacements Wyze sent me had notes on the ticket (in e-mail, when the replacement was processed) instructing me not to return the faulty product and to recycle it. That seems reasonable to me if it’s available, because I hate seeing things unnecessarily go to landfills. I also suspect that it’s more cost effective for Wyze not to have these back: I imagine they’ve decided to that the juice of having engineers spend precious time and other resources troubleshooting a handful of faulty gadgets isn’t worth the squeeze, but that’s just speculation on my part.
I suspect the same, probably shipping costs are higher than the cost of the camera.
Did you recycle or are the cams sitting in a drawer somewhere? Luckily we have recycling drop offs quarterly in our city. Otherwise they would sit on a garage shelf.
I haven’t had any cameras fail (yet), so no need to recycle those. Wyze replaced a doorbell under warranty, but then I did some additional troubleshooting and discovered that whoever had previously installed/wired my chime hadn’t connected it correctly, so resolving that allowed me to continue using my old doorbell (and likely would’ve been an issue for the new one). I connected the new one to make sure it works and stuck it back in the box; it’s listed in my app as a spare.
We have convenient places here that will take electronics for recycling, too. I dropped off an older all-in-one PC with a cracked screen at a uBreakiFix after I cannibalized the hard drive. At some point I’ll probably recycle a Wyze Bulb that’s been flakin’ out on me.
New profile picture so festive! ![]()
'Tis the season. Merry Chrismas ![]()
