Setting up Rules - mute notifications
I would like to Turn Off all the notifications for select camera between 8am and 8pm. This is the rule that i have, but something is missing since i am still getting notifications. What am i missing? Do i need another rule?
Try going into the camera settings and turning notifications off. Then you just let the rule or schedule turn it on at the appropriate time. You may or may not need to restart the app after you do that.
What you have setup should work. There could be a bug. Try making separate rules to turn on the notifications and to turn them off.
Hi @doug11 is this what you had in mind?
Lets see if it is going to work.
Yes, Event Recording for cameras in my living room are scheduled overnight while notifications are turned off. Kind of a two-step process within the settings for a particular camera.
I think its working, i do not see any notifications since 8am. I will have to wait for tonight to verify if the notifications are going to turn on.
