Setting Light Schedule on the WYZE APP
Setting Schedule on the WYZE APP
Option “Turn on lights @ Sunset”
In my opinion, its still to light out @ Sunset.
It would be great to have an option to turn on the lights 1 Hour or so After Sunset.
I Know I can set schedules to exact times but with the option above I would not have to change the times according to the changing Sunset times.
You can do this if you use rules instead of local schedules (but local schedules are better, so this is still a valid request).
Create a rule on the Home page > + > add rule.
Vote for this wishlist to let Wyze know you want an offset on local schedules as well:
Here is one example of a Rule doing what you would like. You can set Rules to ±59 minutes from Sunrise or Sunset:
