It says the blue tooth is connected and setup is complete. But then flashes red and says it timed out. What can I do to fix this problem
What camera Model? Are you following Wyze setup instructions, or simply connecting via bluetooth? If the latter, it won’t work.
Might have to “forget” the other BT connections you have, to insure their is “room” for the Wyze. Later, add them back as needed.
Welcome to the Forum, @castrange0001!
What details can you provide about any troubleshooting you’ve attempted?
https://support.wyze.com/hc/en-us/articles/12037194475931-Wyze-Cam-OG-Setup-Troubleshooting
