Set up issues
I had these set up they worked fine.
I moved and when setting up
my wyze setup button won’t prompt for setup
The les is solid red
It clicks every like 13 seconds and the red light blinks once when it clicks
On only one camera.
Ive tried factory reset (holding set up button down for 10 amd even 20 seconds)
Unplugged and plugged back in
Any help would be greatly appreciated
You say it is a Panv3 and that you have other cams. If those other cams aren’t all Panv3s, then my best guess is you mixed up the power adapters during the move. The Panv3 requires the one that says 2000MA. Most of the other cams use smaller 1000MA ones, which will not run the Panv3. It is probably trying to do the calibration of the motors (the “startup dance”) and doesn’t have enough power to do it, so it is in a constant reboot loop.
1000MA cams will run fine off the 2000MA adapter, but the 2000MA cams will not run right on the 1000MA adapter.
Just a guess.
Thanks, i had a dif power adapter
