Cam v3 - no longer able to set up
Hi all - grateful for some help!
I have a Wyze Cam v3. It’s been working really well indoors as a baby monitor! We sometimes travel around, which means we have to set up each time to connect at a new location. However yesterday I plugged it in to set up, and nothing much happens! No red light comes on and it no longer says ‘ready to connect’. I do hear a bit of random clicking in the camera and for a brief moment the blue light flashes once… then nothing.
I’ve tried the factory reset, putting in a SD card with different firmware updates and following the instructions to reboot from that… but still just some clicks.
Anybody else faced this issue and can help?!
Thanks!
Tim
First step is try a different power source and cable. Especially since you move it around, either of those is suspect.
Thanks K9CCC… tried several different ones; no effect!
Tim
