You need Cam Plus Lite or Cam Plus to get video recordings that will show up on the Events page of the app. Cam Plus Lite will be 12 second videos.
If you have Cam Plus Lite the 12 Sec videos are backed up to the SD in the base if you have it turned on to do so under event recordings setting. Backup to the base does not work with Cam Plus.
There is no playback from the SD card with the WCO like on the plug in cameras. The SD in the cam is for Scheduled event recording, travel mode and Time Lapse.
WCO information: The version one and two operate the same. Read about the features and the FAQ section.
The V3s and the WCOs operate differently than eachother due to the WCOs have a battery to power them vs the plug in power. Some of the functions are the same, but some are different to maximize the life of the battery charge.
I love my V3s, and if power is anywhere near your camera location, highly recommend those unless “pir detection system” and “no power any where near camera location” are deal breakers on your use case.
I have found a camera that you really need to investigate, it seems a much better option than anything Ive seen thus far A security camera called Keilini that doesn’t require any contract that can be plugged into any light socket even outdoor that has motion detection, infrared and uses wifi to save to a smart phone unlimited videos with immediate alerts Finally, A New Powerful Security Device That Secures My Home In Minutes Without Emptying the Bank Account!
