SD Card Reader for Videos from Camera SD Card
Mac user here with several wyze cams and microSD cards. Can I pull out the card and pull the video directly from the card to my Mac using a microSD card reader?
Assuming the Mac behaves similar to a PC, the answer is yes.
Yep, they’re 1 minute clips organized by date and time. You can get a video stitching program to combine several together.
I don’t use a Mac but I don’t see why it wouldn’t support MPEG4 files, pretty sure they used them before most others. Worst case the OS should install a decoder if needed.
As a Mac user myself, definitely possible. You can use VLC, HandBrake… you name it!
