SD Card not formatting
my sd cards will not format in the cameras. I select format, it appears to format by saying formatting then says format completed but the card still has the same storage capacity used. I have 5 different cameras, 3 won’t format and 2 of them do.
If you really need to format the uSD cards, pull them out and put in either a working camera or a PC to format.
HOWEVER, there is almost never a need to format the uSD cards in the cameras. I have 28 Wyze camera - all of which have uSD cards that are set for continuous recording. I think I could count the number of times I have formatted any of them on the fingers of one hand, with spares.
High Endurance Cards:
It is very possible that your cards are developing read/write problems. There is a lot of info on continuous recording that video cards like the ones in our cams are subjected to. Standard data cards are not designed for it and develop problems, and the cards sold by Wyze aren’t High Endurance cards. I switched several of my cams months age and a number of oddball problems went away. In regard to formatting the cards, best practice is to format the card in a laptop device using the program below and the Full or Deep option which will overwrite/repair any bad tracks which the camera option will not. Here are some resources:
Info on High Endurance Cards
Memory card formatter
one it does that, go into the cmera settings and do the restart camera. for some reaso I have had that happen as well where it says it formatrted, but still shows space being taken up, when I did a restart and looked again it’s as if it read it again and now the card was empty…
that was on a quality high endurance card too just fyi.
That restart method cleared it to “0.0G” for me, too. My v2 fixed cam with 8gb card kept showing “1.92G” space used after 3 formats that gave no faults.
What does it show? It should show close to what the card size is after a format (roughly, no one quotes what it is after formatting, which takes space). After some time IF the camera is set to record to the SD card, then the space available should start shrinking. But if you format it 1,000 times in a row, it will always show the same space after formatting, so not much info in that statement.
Restart camera after format. It works after that. Probably the cache isn’t cleared on the display.
Bam’s recommendation worked great for me. (All was good after restarting the camera.)
That’s putting a lot of wear on those cards; how long did they last since you posted that in 2021? I tend to do Continuous recording only in special circumstances.
I just looked at my camera listing. I did not document the SD cards when I first started using Wyze cameras in 2018, but I do show a bunch of cards bought in April of 2019 that are still working. All of my cameras are always set to continuous recording.
One important note. Use good quality High Endurance cards that are designed for continuous recording. Cheap cards WILL NOT LAST. That includes the original cards that Wyze sold - none lasted six months. I hope the newer ones are better, but I would not trust them. I have had great success with SanDisk High Endurance cards.
In my case I have 4x 128GB Sandisk Pro Endurance cards that have been doing continuous recording for 3 years straight now. Based on my calculations (using their published endurance spec and the write speed of the Wyze cams) they should last 16 years. But I’ll be happy if they last the 5 year warranty period. Hopefully by then prices have come back down.
My other cams are motion only and don’t get a lot of events, those just have random halfway decent cards that I had laying around.
laughing
I looked at the price today, US Dollar ($63.00) for 128 GB and ($105.00) for a 256 GB Pro Endurance card.
I have both 128GB and 256GB, cards, the last 256GB I purchased was expensive at $39.00.
But they are Raccoon, Skunk and Possum approvved. :rofl:
Yeah I keep them in my amazon “saved for later” just to monitor prices. I bought mine for $14 each back in 2023. If only I had known…
I thought it was bad when the went up to $20 in 2024.
Reminds of the early 90’s when you needed a second mortgage to by a megabyte of RAM :rofl:
I went back and checked last purchase of a 256GB Samsung. It was $29.99 + Tax from the Samsung Store on Amazon 1 December 2025.
Sometime in the mid 90s I recall saving my lawn mowing money for months to buy I believe a 4MB upgrade kit. PNY I believe was the common retail brand. Back when there were computer stores in the mall (though can’t recall the name of this particular one).
Really sped up that 386-SX PC though.
I think I paid something like $CAD1,600 for a 4MB stick. Might have been Kingston, but not 100% sure.
