Regarding the MicroSD cards–
Will any of the WYZE cameras handle a 64-bit SD card opposed to the 32-bit? Or is the 32-bit MicroSD card the limit in terms of storage?
Thanks All.
Thanks All.
32 is the official limit but there are many people running much bigger cards. the problem is the format of the cards. I cant post links to all the topics on that so just do a quick search at the top right of the page…you will find a great many things on the topic. but keep in mind Wyze does not condone using cards bigger than 32 GB
I ran out of “official” cards, stuck a 128GB in at it was recognized fine. Did nothing special as far as formatting it.
Thanks for the kind response, Bam. I felt that the possibility of dropping a larger card in place might work but I’m thinking that much as formatting deals directly with capacity of storage, the system may not at present carry the ability to expand beyond what it’s programmed to handle.
Thanks, I can certainly test a couple of larger SD cards just for grins. Thanks for the kind response.
