Scheduled Maintenance - 2/8/23 12:00 AM PT
Hello, everyone.
We have some scheduled maintenance coming up.
February 8th 12:00 AM PT Scheduled Maintenance
The Wyze app and Wyze websites will be down for scheduled maintenance on February 8th at 12:00 AM PT. The process is expected to be completed by 2:00 AM PT. Here’s the scope of impact:
Wyze Cams:
  • Event Videos will not be uploaded to the cloud during this time.
  • Notifications from during that time will not be sent.
Wyze Sense:
  • Rules that would be triggered by Wyze Sense in the maintenance window will not work.
Wyze Services:
Cam Plus:
  • Event Videos will not be uploaded to the cloud.
  • AI tags will not be generated.
  • Notifications from that time will not be sent.
Cam Protect:
  • AI tags like Person Detection will not be generated.
  • Arming and disarming the system will not work.
  • Alarms will not trigger the siren on the Wyze Cam.
  • Noonlight will not be contacted.
Wyze Home Monitoring:
  • Arming and disarming through the app will not work.
  • The physical Wyze Sense Keypad will still be able to cancel alarms and arm/disarm your system.
  • Alarms that occur during the maintenance window will trigger the Wyze Sense Hub siren.
Wyze Lock and Wyze Lock Bolt:
  • Keypads will still work without the cloud service.
  • The fingerprint scanner will still work without the cloud service.
  • Unlocking with the app and auto-unlock WILL NOT function during the maintenance window.
Wyze Thermostat:
  • The thermostat itself can work without internet but heating/cooling usage data and HVAC filter life data will be lost.
  • Geofencing may not work.
Wyze Mesh Router:
  • The router will continue to function.
  • Some setting changes will be unavailable.
Thank you for your attention!
What kind of sweet updates/improvements are we getting? :slight_smile:
What about the Lights, and switches? I would guess that they would function like normal switches. But I don’t know about the Wyze light bulbs.
There is a setting called “Power Loss recovery” where you can tell the bulbs “turn the light on” so that if you ever turn off the power to light then turn it back on manually with the switch, the bulb automatically comes back on. Then the bulb will still work just like a normal non-smart LED bulb. Then when the internet is restored, it will go back to all the other smart functions being available again.
It is possible that some of the bulbs may have SOME functionality without internet as they have Bluetooth.
Pretty wild to shut down functionality of a home security system for a few hours and broadcast to the world the exact time it will happen. You might want to put some thought the implications of this type of thing before deciding to move forward
For anyone wondering, they sent an email to HMS owners explaining:
  • You will still be able to use the physical Wyze Sense Keypad to cancel alarms or arm/disarm your system.
  • Alarms that occur during the maintenance window will trigger the siren on your Wyze Sense Hub, but your system may not request the Noonlight dispatching service.
So, we can still arm and disarm the system (locally) and the alarm/siren will still go off, a person just needs to dial 911 themself.
The email says it’s an upgrade to the cloud infrastructure. I hope that means things are going to be a lot more smoother. :slight_smile:
I appreciate Wyze letting me know when things change temporarily from what I would normally expect and letting me know that I would need to manually call stuff in myself.
We actually did take this into account, we did not want to do it so early that people could become a target but also give enough time that people could make adjustments and be prepared.
…and what do you say to folks who are out of town whose alarm triggering wake the neighbors in the middle of the night with no apparent way to shut it off? Since Noonlight won’t receive the alarm, will the neighbors call the cops due to the unusual noise at that time? How long will an alarm continue to blare without human intervention? The Wyze alarm owner’s hands are tied since they cannot turn it off either!! So please play out that scenario for us! No back door way to shut it off remotely!!!
If an alarm goes off with a person not there and Noonlight can’t call the cops, I would appreciate it if it caused my neighbors to look at my house and call the cops. But, for what it’s worth, the siren times out all on its own after I believe 10 minutes anyway.
A person concerned about the remote property scenario can make the informed decision which risk they prefer: have the siren go off for 10 minutes and the neighbors call the cops, or turn the alarm system off in advance for a couple of hours or so so that this doesn’t happen (incidentally, the cameras should continue to record locally to an SD card even during outages, so footage can reviewed later). I, myself, will probably just leave mine on.
Incidentally, I found examples of similar scheduled maintenance downtimes causing similar concerns with most other Home security companies as well, including ADT, Honeywell, Simplisafe, etc. which indicates this isn’t something specific to Wyze or abnormal in the security industry, but hopefully such downtime instances will be rare because none of us like things not working exactly as we want them to.
Wow just wow. Is this going to be normal? The year of the camera? Huh? Let’s shut down all camera events for millions of security cameras even if some customers pay for a service. I realize it’s only a few hours but come on. Wyze needs to improve their clouds redundancy.
I think he was talking about false alarms being triggered. Sorry, It’s not normal. I’ve had Ring and Reolink for several years and nope never happened. They just had periodic outages like wyze. This is good to know though especially during the “Year of the Camera”. You guys are making it very difficult for us early supporters to stay with you.
Just saw the wyze home Monitoring system maintenance, what a crazy time at night to have the maintenance, why not during the day - at noon???
So upset with the timing of this maintenance, open invite to burglary? Robbery?
Can we have Wyze Team be much more mindful of timing of these maintenance time frame??
Concerned because some of below might be impacting me — : (
Aaand everything will come back online within 10 minutes.
Again, a hub would not require this.
Overall maintenance should be planned much ahead in advance, giving sufficient heads up to your customers… Is there no thing called a change control??
Is this 1990? Shutting down a system for updates? I cant believe that is still a thing. Wyze needs a better IT team.
better peel off the ‘protected by wyze’ sticker from the window
Along these lines, I always tell people to never advertise the company you use for security with a sign (unless they’re paying you to put their sign up in your yard…and yes I have had companies offer to pay me monthly just to put up their security sign in my yard even if I don’t actually use them :rofl: )…I tell people to always put up a generic sign, so random people don’t feel confident what the system weaknesses are (EVERY company has security weaknesses). Generic signs are best. So this is good advice in general anyway…
IMO:
  • Best = Use a generic sign
  • Second best = use a sign for a company other than the company you actually use for security
  • Next best = use the sign for the company you use
  • Least effective prevention = No sign at all
I do like these Two options, had put the Wyze stickers on 2 windows; removing them will leave behind the sticky mess :frowning:
Going back to the main issue, can this maintenance not be Pushed to some time during day? @WyzeJasonJ @WyzeJimmy
I am fine to wait for the next latest greatest feature, for another month or more, safety & peace of mind comes first
Not speaking for either of those fellas, but I am guessing there are metrics showing when the time of the least amount of alarms or events are, when the times of least rules triggers, least amount of user input into the systems etc etc to find the sweet spot that impacts folks the least. There is no good time that impacts no one, so choosing a time that effects the least is a good course of action. I am guessing that the time chosen reflects that, coupled with engineer availability etc.
